July 14, 2020 at 9:49 am
Ibrahimabdullah
Subscriberhello everyone,
I am trying to get some flow visualization contours of my flying wing but i failed. can anyone guide me to get some surface streamlines and some vortex shedding.
the first picture is my own pressure contour and the following 2 pictures from the literature as a reference to what i want to get for my flying wing.
thank you.
July 15, 2020 at 1:06 am
Karthik Remella
AdministratorIt looks like the postprocessing was done using another tool called Tecplot. Tecplot can read Fluent files. You should also be able to use CFD Post to get the images of these streamlines.
I hope this helps.
Thanks.
Karthik
July 15, 2020 at 4:43 am
Ibrahimabdullah
Subscriberdefinitely helps a lot. i will try to get the tools you mentioned above to do my flow visualization.
really appreciate it.
thank you
July 15, 2020 at 3:48 pm
Karthik Remella
AdministratorSure. If the answer was useful, please mark it as 'Is Solution' to benefit others on the community.
Thanks.
Karthik
- The topic ‘surface streamlines and vortex shedding’ is closed to new replies.
6450
