November 18, 2018 at 3:36 pm
November 18, 2018 at 4:35 pm
peteroznewman
SubscriberClick on Mesh, in the Details window is Element Size and it is currently set to Default. Type a number to set a specific size, like 100 mm.
November 18, 2018 at 4:46 pm
Aloush993
SubscriberThank you for replying it didn't workÂ
I used the share topology as merge and share , they gave me this error , while I used the share topology as group , it worked but now I have another problem is the size limitation by student version!
can you explain what is share topology used to solve ?
November 18, 2018 at 9:14 pm
peteroznewman
SubscriberIf you have two bodies that are bonded together, like a steel column set into concrete. You could have two bodies and use bonded contact to connect them. That allows you to plot results at the interface, and adds some elements to the model. Or you could use Shared Topology, where either DesignModeler or SpaceClaim will recognize a face that his common to both parts and mark it so. Then the mesher will just put down one set of nodes on that face and both bodies have elements that use those nodes. The two bodies are now connected to shared nodes.
To make your model smaller for the Student license limits, you can use 1/4 symmetry if your model had symmetric loading. You can replace thin solid sections with sheet bodies and you can replace long slender solid beams with line bodies and instead of using solid elements, you will use shell elements and beam elements.
- The topic ‘surface meshing was successful but tetrahedral meshing failed ansys’ is closed to new replies.
5054
1764
1387
1248
