TAGGED: #fluent-#cfd-#ansys, 2d-simulation, fluent-mesh
September 9, 2024 at 9:27 pm
corentin.roth
SubscriberHi,
I'm curretly working on fluent, and i was trying to calculate the Area of my 2D geometry. I know its surface from DesignModeler (8158 mm²). But i wanted to use the tool "Surface integrals". When i use this tool, the result is 17m² (approx). I triple checked every dimensions of my geometry, I even used the ruler in Fluent to determine if wether it had the good dimensions or not. I guess if the area calculated by "surface integrals" is wrong, the volumetric flow rate is also wrong etc.. So I was wondering if anybody could help me to solve this issue.
Sincerly !
September 10, 2024 at 8:30 am
Essence
Ansys EmployeeHello,
Please check the reference values again. To map the 3D to 2D, you need to input reference values correctly.
5649
1885
1404
1303
