Preprocessing
Preprocessing
Surface generation
    • Amith_Anoop_Kumar
      I am trying to create a surface for the below sketch but surface is being only generated for the circle, but i need a rectangular surface with a circular hole
    • Sahil Sura
      This geometry seems to be modeled in Design Modeler, On completion of the sketching, Click on 'Concepts' tab and select 'Surfaces from sketches' option. By clicking all the respective sketched geometries, and clicking the Generate option, a surface will be generated for the same. Seems the presence of other unintended lines is hampering the surface generation for the rectangle , cleaning the sketch may prove out to be useful.
      You can also use SpaceClaim to generate the same with ease.
      Following references may help you on the same-
      Surfaces From Sketches (ansys.com)
      Thanks Sahil
  • The topic ‘Surface generation’ is closed to new replies.
