June 24, 2020 at 5:39 pm
marleyalbright
Hello, I am new to using Ansys Design modeler and I am following a tutorial, Multiphase flow simulation for VOF method. I am trying to have two parts, two bodies from two sketches but when I use the concept->surface from sketch for the rectangle and the circle, the circle doesn't register as a body. Can anyone help me with this?
June 25, 2020 at 3:31 am
Keyur Kanade
Ansys Employeeplease use tools - project.Â
project that circle to rectangle.Â
then it will have that circle as a separate face.Â
please see help document for more details about project.Â
also check following
https://www.youtube.com/watch?v=DWKhKFCxZow
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘Surface from sketch’ is closed to new replies.
5864
