October 7, 2024 at 4:39 am
sooriaprakash.kamaraj
SubscriberI have done the erosion analysis coupled with dynamic meshing. I could see the deformed/eroded surface in contour.
I want to export that deformed/eroded surface from ansys in STL file format or any other standard CAD modelling format.
Anyone help me on it?
October 7, 2024 at 10:50 am
Forum ModeratorThe simple approach is to export a VRML via post processing. Otherwise, if you read the boundary mesh into Fluent Meshing you should be able to strip everything you don't want to take the eroded surface mesh into CAD.Â
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
1495
1386
1209
