March 11, 2024 at 4:18 am
Dhanashri Wankhede
SubscriberI am simulating Icepak in SIwave, simulation is getting stuck at 66% everytime without getting any error. Can you please suggest me what might be the possible reasons for this.
March 11, 2024 at 3:32 pm
Praneeth
Ansys EmployeeHi Dhanashri,
Thank you for reaching out to the Ansys learning forum.Â
Please elaborate on your issue to help us serve you better. It is not clear whether you are using Icepak or SIwave. Kindly share details like tool version, snapshots of the setup which might help in the troubleshooting.
Best regards,
Praneeth. -
March 26, 2024 at 5:48 am
Dhanashri Wankhede
SubscriberI am simulating ICEPAk but it is getting stuck at in between, in ICEPAK simulation setup, if I keep thermal simulation type as conduction I am getting my simultion result but only for basic meshing details. I have attached setup snap for reference
if I keep thermal simulation type as convection simulation is stuck in between even if i keep my simultion running for day or 2.
can enyone suggest what might be the possible causes and what will be the solution to this.
I have already checked my PCÂ performace, its having enogh CPU cores and memory available.
April 17, 2024 at 2:01 pm
Praneeth
Ansys EmployeeHi,
Thanks for your reply, your patience is much appreciated.Â
Please note that your model has to be reviewed to provide suggestions for optimum simulation. Unfortunately, it is not possible through this forum because of certain restrictions due to its public nature. Kindly raise a case if you have service access for getting one-to-one assistance.
Best regards,
Praneeth.Â
- The topic ‘support for Icepak simulation.’ is closed to new replies.
5664
1890
1419
1304
.png)
