March 26, 2019 at 7:50 pm
akin3rd
SubscriberI would like to simulate the suction on an airfoil using fluentÂ
the airfoil diagram is shown below, there is a suction slot which the sucked air flows through that leads to the low-pressure cavity which causes the suction.
The idea is to induce high energy turbulent mixing in the boundary layer flow and delay/prevent flow separation, thereby preventing stall
How do I simulate this environment in ANSYS Fluent.
Thanks
March 27, 2019 at 8:05 am
Keyur Kanade
Ansys Employeeplease check this
though its old, it will help you get through process.Â
https://confluence.cornell.edu/display/SIMULATION/FLUENT+-+Flow+over+an+Airfoil-+Problem+Specification
April 5, 2019 at 4:49 pm
akin3rd
SubscriberHello,
I don't see any tutorials on how to create suction.
I just need to know how to create a low-pressure environment in the suction cavity i.e. how do I specify boundary conditions that create a low-pressure environment?
Thanks
January 9, 2020 at 7:58 am
Harak
SubscriberDid you found an answer to this question? I have the same problem.Â
January 9, 2020 at 9:01 am
peteroznewman
SubscriberI'm not a CFD expert, but I would assign the vertical edge inside the low pressure cavity to be a Pressure Outlet. Assign a negative gauge pressure to that outlet. That creates the suction.
There would be a large air domain around the airfoil with an inlet velocity boundary condition on the left side, and a pressure outlet boundary condition on the right side that would have a zero gauge pressure.
January 9, 2020 at 10:21 am
akin3rd
SubscriberI changed the geometry entirely, what I did was to make a section of the airfoil wall a velocity inlet BC or a pressure outlet BCÂ
July 25, 2020 at 5:23 am
zafi41
Subscriberhello man..I am trying to do this same problem. But split the edge of the upper surface of NACA 0018 and define pressure outlet BC. But if I create slot at 60% length of the chord, mesh on the face adjacent to the slot becomes unstructured. Can you please give me some solution.. I need to complete this urgently.
- The topic ‘Suction simulation’ is closed to new replies.
6380
