TAGGED: beam, contact, convergence, static-structural
July 17, 2024 at 8:03 am
moritz.ursprung
SubscriberHi,
I am performing a contact analysis with several beams beeing rotated into contact. The bottom ends of the beams are unconstrained, except the split beams (see picture below) have their nodes coupled with each other to simulate linear periodicity.
Between the beams frictional contacts are set, also between beams and casing frictional contacts are set.
For the first row the simulation kind of works (penetration is a little high, but I can adapt the contact stiffness).
But after this point the simulation fails to converge further supsteps, eventough the solution output states that force, moment and displacement criteria are met during iterations:
In earlier supsteps the solution stops and moves on to the next substep.
What could be the problem here? Are there other criteria I should look at? Or should I use transient mechanical, eventough there should be no further movement after all the beams have arranged?
Thanks in advance for any hints!
July 17, 2024 at 1:28 pm
Ashish Khemka
Forum ModeratorHello,
Can you try increasing the number of iterations? Default is 25. Issue NEQIT command under the setup and increase the number of equilibrium iterations to say 50 or 100.
Ashish Khemka
July 17, 2024 at 2:59 pm
Sai Deogekar
Ansys EmployeeIt is a bit strange that the force, moment and displacement criteria show converged but the solution isn't converging. Is there any other error or warning being displayed? Maybe you can share that so that forum members can help you investigate this issue.
July 17, 2024 at 4:18 pm
mrife
Ansys EmployeeHi moritzursprung
Force and moment (and possibly displacement and rotations) are not the only convergence criteria that may be activated. Others include contact penetration, volume (for incompressible materials), strain step size for plastic and creep,.....I feel like I'm missing another but you get the point. It's very possible that while the force and moment convergence criteria have been met some other criteria has not. You'll need to review more of the output.
Mike
July 18, 2024 at 9:02 am
moritz.ursprung
SubscriberHi,
thank you for the suggestions!
I already increased the number of iterations up to 100, but the number of predicted iterations till convergence kept increasing along. So this could not solve the issue.
There are certainly some warning messages, but with the same warning messages I was able to achieve a converged solution in similar models. The solver output shows some more warning messages. I have not lokked at alle of them yet.
Twice in the solver output there is an error message about too much penetration after a substep, but after a bisection the substeps keep converging.
The final error message only reads:
Solution not converged at time 0.466149349 (load step 1 substep 61).
Run terminated.@ Mike: where can I check which other convergence criteria are activated and how their values develop over the solution? I could not find them in the solve.out file or the solver output
Moritz
July 19, 2024 at 12:38 am
mrife
Ansys EmployeeHi Moritz
They should be around the same location as you showed in the screen shot of the output file. Could you screen shot more of the file? Near where you did before.
July 19, 2024 at 12:13 pm
July 19, 2024 at 1:01 pm
mrife
Ansys EmployeeMortiz
Can you attach the whole out file? Some of the alternative convergence items are not reported every Newton Rhapson iteration so you need to look at the last iteration of the substep.
July 25, 2024 at 4:02 pm
moritz.ursprung
SubscriberHi Mike,
here is the out code for one hole substep until the bisection. After iteration 15 all three criteria are converged, but it keeps running.
Sorry for the long code. I tried to attach the .out file with the picture upload, but i am not sure if this works. Is there any other way to attach the file and would you be allowed to open it?
>>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION 10
*** LOAD STEP 1 SUBSTEP 68 COMPLETED. CUM ITER = 883
*** TIME = 0.470336 TIME INC = 0.187712E-03
*** AUTO STEP TIME: NEXT TIME INC = 0.18771E-03 UNCHANGEDFORCE CONVERGENCE VALUE = 0.2363E-01 CRITERION= 0.5000E-04
MOMENT CONVERGENCE VALUE = 0.2079E-06 CRITERION= 0.5000E-04
DISP CONVERGENCE VALUE = 0.4420E-01 CRITERION= 0.2221E-02
EQUIL ITER 1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.4420E-01
DISP CONVERGENCE VALUE = 0.2210E-02 CRITERION= 0.2221E-02 <<< CONVERGED
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.2210E-02
FORCE CONVERGENCE VALUE = 0.9451E-01 CRITERION= 0.5000E-04
MOMENT CONVERGENCE VALUE = 0.1958E-06 CRITERION= 0.5000E-04 <<< CONVERGED
EQUIL ITER 2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7094E-02
DISP CONVERGENCE VALUE = 0.1649E-02 CRITERION= 0.2221E-02 <<< CONVERGED
LINE SEARCH PARAMETER = 0.2324 SCALED MAX DOF INC = 0.1649E-02
FORCE CONVERGENCE VALUE = 0.5635E-01 CRITERION= 0.5000E-04
MOMENT CONVERGENCE VALUE = 0.1496E-06 CRITERION= 0.5000E-04 <<< CONVERGED
EQUIL ITER 3 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.2251E-02
DISP CONVERGENCE VALUE = 0.2244E-02 CRITERION= 0.2221E-02
LINE SEARCH PARAMETER = 0.9966 SCALED MAX DOF INC = -0.2244E-02
FORCE CONVERGENCE VALUE = 0.2978E-02 CRITERION= 0.9964E-03
MOMENT CONVERGENCE VALUE = 0.4766E-07 CRITERION= 0.5000E-04 <<< CONVERGED
EQUIL ITER 4 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2553E-01
DISP CONVERGENCE VALUE = 0.1277E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.1277E-02
FORCE CONVERGENCE VALUE = 0.4693E-01 CRITERION= 0.1022E-02
MOMENT CONVERGENCE VALUE = 0.3969E-07 CRITERION= 0.5000E-04 <<< CONVERGED
EQUIL ITER 5 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6809E-02
DISP CONVERGENCE VALUE = 0.3405E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.3405E-03
FORCE CONVERGENCE VALUE = 0.4141E-01 CRITERION= 0.1029E-02
MOMENT CONVERGENCE VALUE = 0.3775E-07 CRITERION= 0.5000E-04 <<< CONVERGED
EQUIL ITER 6 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1395E-02
DISP CONVERGENCE VALUE = 0.1393E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9987 SCALED MAX DOF INC = -0.1393E-02
FORCE CONVERGENCE VALUE = 0.5996E-04 CRITERION= 0.9939E-03 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1476E-07 CRITERION= 0.5000E-04 <<< CONVERGED
EQUIL ITER 7 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.9917E-02
DISP CONVERGENCE VALUE = 0.4959E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.4959E-03
FORCE CONVERGENCE VALUE = 0.1406E-01 CRITERION= 0.1177E-02
MOMENT CONVERGENCE VALUE = 0.1405E-07 CRITERION= 0.5877E-04 <<< CONVERGED
EQUIL ITER 8 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.9762E-03
DISP CONVERGENCE VALUE = 0.9746E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9984 SCALED MAX DOF INC = -0.9746E-03
FORCE CONVERGENCE VALUE = 0.3751E-04 CRITERION= 0.1191E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1479E-08 CRITERION= 0.5997E-04 <<< CONVERGED
EQUIL ITER 9 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1001E-02
DISP CONVERGENCE VALUE = 0.6913E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.6906 SCALED MAX DOF INC = 0.6913E-03
FORCE CONVERGENCE VALUE = 0.5164E-03 CRITERION= 0.1225E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.7677E-09 CRITERION= 0.6119E-04 <<< CONVERGED
EQUIL ITER 10 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.9547E-02
DISP CONVERGENCE VALUE = 0.4773E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.4773E-03
FORCE CONVERGENCE VALUE = 0.1324E-01 CRITERION= 0.1259E-02
MOMENT CONVERGENCE VALUE = 0.8000E-09 CRITERION= 0.6244E-04 <<< CONVERGED
EQUIL ITER 11 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1118E-02
DISP CONVERGENCE VALUE = 0.1115E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9969 SCALED MAX DOF INC = -0.1115E-02
FORCE CONVERGENCE VALUE = 0.3552E-04 CRITERION= 0.1266E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.7946E-09 CRITERION= 0.6372E-04 <<< CONVERGED
EQUIL ITER 12 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1145E-01
DISP CONVERGENCE VALUE = 0.5727E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.5727E-03
FORCE CONVERGENCE VALUE = 0.1583E-01 CRITERION= 0.1302E-02
MOMENT CONVERGENCE VALUE = 0.8317E-09 CRITERION= 0.6502E-04 <<< CONVERGED
EQUIL ITER 13 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7118E-02
DISP CONVERGENCE VALUE = 0.3559E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.3559E-03
FORCE CONVERGENCE VALUE = 0.2109E-01 CRITERION= 0.1332E-02
MOMENT CONVERGENCE VALUE = 0.8110E-09 CRITERION= 0.6634E-04 <<< CONVERGED
EQUIL ITER 14 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.8219E-03
DISP CONVERGENCE VALUE = 0.8209E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9987 SCALED MAX DOF INC = -0.8209E-03
FORCE CONVERGENCE VALUE = 0.2696E-04 CRITERION= 0.1344E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.9852E-09 CRITERION= 0.6770E-04 <<< CONVERGED
EQUIL ITER 15 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.3389E-02
DISP CONVERGENCE VALUE = 0.1695E-03 CRITERION= 0.2221E-03 <<< CONVERGED
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.1695E-03
FORCE CONVERGENCE VALUE = 0.5420E-03 CRITERION= 0.2752E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.8863E-09 CRITERION= 0.1382E-03 <<< CONVERGED
EQUIL ITER 16 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.9505E-02
DISP CONVERGENCE VALUE = 0.9505E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.9505E-02
FORCE CONVERGENCE VALUE = 1.268 CRITERION= 0.1649E-02
MOMENT CONVERGENCE VALUE = 0.4744E-06 CRITERION= 0.7049E-04 <<< CONVERGED
EQUIL ITER 17 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1003E-01
DISP CONVERGENCE VALUE = 0.1002E-01 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9994 SCALED MAX DOF INC = -0.1002E-01
FORCE CONVERGENCE VALUE = 0.1474E-01 CRITERION= 0.1408E-02
MOMENT CONVERGENCE VALUE = 0.2378E-05 CRITERION= 0.7193E-04 <<< CONVERGED
EQUIL ITER 18 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7293E-02
DISP CONVERGENCE VALUE = 0.7976E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.1094 SCALED MAX DOF INC = 0.7976E-03
FORCE CONVERGENCE VALUE = 0.1563E-01 CRITERION= 0.1463E-02
MOMENT CONVERGENCE VALUE = 0.2162E-05 CRITERION= 0.7340E-04 <<< CONVERGED
EQUIL ITER 19 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.3289E-02
DISP CONVERGENCE VALUE = 0.3228E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9779 SCALED MAX DOF INC = -0.3216E-02
FORCE CONVERGENCE VALUE = 0.2607E-02 CRITERION= 0.1499E-02
MOMENT CONVERGENCE VALUE = 0.1729E-05 CRITERION= 0.7489E-04 <<< CONVERGED
EQUIL ITER 20 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2482E-03
DISP CONVERGENCE VALUE = 0.2482E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.2482E-03
FORCE CONVERGENCE VALUE = 0.2441E-04 CRITERION= 0.1529E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.6466E-07 CRITERION= 0.7642E-04 <<< CONVERGED
EQUIL ITER 21 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1208E-01
DISP CONVERGENCE VALUE = 0.6039E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.6039E-03
FORCE CONVERGENCE VALUE = 0.1757E-01 CRITERION= 0.1572E-02
MOMENT CONVERGENCE VALUE = 0.6139E-07 CRITERION= 0.7798E-04 <<< CONVERGED
EQUIL ITER 22 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6784E-02
DISP CONVERGENCE VALUE = 0.3392E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.3392E-03
FORCE CONVERGENCE VALUE = 0.2323E-01 CRITERION= 0.1608E-02
MOMENT CONVERGENCE VALUE = 0.5832E-07 CRITERION= 0.7957E-04 <<< CONVERGED
EQUIL ITER 23 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1163E-02
DISP CONVERGENCE VALUE = 0.1161E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9983 SCALED MAX DOF INC = -0.1161E-02
FORCE CONVERGENCE VALUE = 0.3418E-04 CRITERION= 0.1612E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1587E-08 CRITERION= 0.8120E-04 <<< CONVERGED
EQUIL ITER 24 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1143E-01
DISP CONVERGENCE VALUE = 0.5715E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.5715E-03
FORCE CONVERGENCE VALUE = 0.1608E-01 CRITERION= 0.1657E-02
MOMENT CONVERGENCE VALUE = 0.1556E-08 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 25 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.5716E-03
DISP CONVERGENCE VALUE = 0.5710E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9990 SCALED MAX DOF INC = -0.5710E-03
FORCE CONVERGENCE VALUE = 0.1296E-04 CRITERION= 0.1648E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.7639E-09 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 26 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7305E-02
DISP CONVERGENCE VALUE = 0.7305E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.7305E-02
FORCE CONVERGENCE VALUE = 0.6054E-03 CRITERION= 0.1824E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.2101E-06 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 27 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.8151E-02
DISP CONVERGENCE VALUE = 0.4076E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.4076E-03
FORCE CONVERGENCE VALUE = 0.5637E-02 CRITERION= 0.1830E-02
MOMENT CONVERGENCE VALUE = 0.1998E-06 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 28 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.3668E-02
DISP CONVERGENCE VALUE = 0.1490E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.4062 SCALED MAX DOF INC = -0.1490E-02
FORCE CONVERGENCE VALUE = 0.4698E-01 CRITERION= 0.1797E-02
MOMENT CONVERGENCE VALUE = 0.1315E-06 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 29 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.7516E-02
DISP CONVERGENCE VALUE = 0.7505E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9985 SCALED MAX DOF INC = -0.7505E-02
FORCE CONVERGENCE VALUE = 0.5391E-03 CRITERION= 0.1653E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.4922E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 30 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.4490E-01
DISP CONVERGENCE VALUE = 0.2245E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.2245E-02
FORCE CONVERGENCE VALUE = 0.1010 CRITERION= 0.1696E-02
MOMENT CONVERGENCE VALUE = 0.4694E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 31 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1065E-01
DISP CONVERGENCE VALUE = 0.2137E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.2007 SCALED MAX DOF INC = 0.2137E-02
FORCE CONVERGENCE VALUE = 0.5885E-01 CRITERION= 0.1741E-02
MOMENT CONVERGENCE VALUE = 0.4479E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 32 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5513E-02
DISP CONVERGENCE VALUE = 0.7573E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.1374 SCALED MAX DOF INC = 0.7573E-03
FORCE CONVERGENCE VALUE = 0.5167E-01 CRITERION= 0.1742E-02
MOMENT CONVERGENCE VALUE = 0.4088E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 33 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.2585E-02
DISP CONVERGENCE VALUE = 0.2585E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9998 SCALED MAX DOF INC = -0.2585E-02
FORCE CONVERGENCE VALUE = 0.9949E-04 CRITERION= 0.1644E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.5927E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 34 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.9754E-02
DISP CONVERGENCE VALUE = 0.4877E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.4877E-03
FORCE CONVERGENCE VALUE = 0.1298E-01 CRITERION= 0.1657E-02
MOMENT CONVERGENCE VALUE = 0.5624E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 35 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4552E-03
DISP CONVERGENCE VALUE = 0.4544E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9983 SCALED MAX DOF INC = -0.4544E-03
FORCE CONVERGENCE VALUE = 0.2127E-04 CRITERION= 0.1646E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.2622E-08 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 36 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.4943E-02
DISP CONVERGENCE VALUE = 0.4943E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.4943E-02
FORCE CONVERGENCE VALUE = 0.2253E-03 CRITERION= 0.1710E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.6086E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 37 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1127E-01
DISP CONVERGENCE VALUE = 0.5637E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.5637E-03
FORCE CONVERGENCE VALUE = 0.1577E-01 CRITERION= 0.1720E-02
MOMENT CONVERGENCE VALUE = 0.5781E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 38 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2376E-02
DISP CONVERGENCE VALUE = 0.1188E-03 CRITERION= 0.2221E-03 <<< CONVERGED
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.1188E-03
FORCE CONVERGENCE VALUE = 0.1630E-01 CRITERION= 0.3443E-02
MOMENT CONVERGENCE VALUE = 0.5491E-07 CRITERION= 0.1657E-03 <<< CONVERGED
EQUIL ITER 39 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.5277E-02
DISP CONVERGENCE VALUE = 0.5248E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9945 SCALED MAX DOF INC = -0.5248E-02
FORCE CONVERGENCE VALUE = 0.2628E-03 CRITERION= 0.1642E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.3069E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 40 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1145E-01
FORCE CONVERGENCE VALUE = 0.1583E-01 CRITERION= 0.1655E-02
MOMENT CONVERGENCE VALUE = 0.2916E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 41 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6989E-02
DISP CONVERGENCE VALUE = 0.3494E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.3494E-03
FORCE CONVERGENCE VALUE = 0.1534E-01 CRITERION= 0.1660E-02
MOMENT CONVERGENCE VALUE = 0.2770E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 42 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.6403E-03
DISP CONVERGENCE VALUE = 0.6393E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9984 SCALED MAX DOF INC = -0.6393E-03
FORCE CONVERGENCE VALUE = 0.1531E-04 CRITERION= 0.1645E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.9477E-08 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 43 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5155E-02
DISP CONVERGENCE VALUE = 0.3930E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.7625 SCALED MAX DOF INC = 0.3930E-02
FORCE CONVERGENCE VALUE = 0.1429E-03 CRITERION= 0.1696E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.3352E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 44 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1132E-01
DISP CONVERGENCE VALUE = 0.5660E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.5660E-03
FORCE CONVERGENCE VALUE = 0.1581E-01 CRITERION= 0.1706E-02
MOMENT CONVERGENCE VALUE = 0.3184E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 45 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.3328E-02
DISP CONVERGENCE VALUE = 0.1664E-03 CRITERION= 0.2221E-03 <<< CONVERGED
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.1664E-03
FORCE CONVERGENCE VALUE = 0.1557E-01 CRITERION= 0.3417E-02
MOMENT CONVERGENCE VALUE = 0.3024E-07 CRITERION= 0.1657E-03 <<< CONVERGED
EQUIL ITER 46 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4326E-02
DISP CONVERGENCE VALUE = 0.4303E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9947 SCALED MAX DOF INC = -0.4303E-02
FORCE CONVERGENCE VALUE = 0.1694E-03 CRITERION= 0.1644E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1978E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 47 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1146E-01
DISP CONVERGENCE VALUE = 0.5728E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.5728E-03
FORCE CONVERGENCE VALUE = 0.1586E-01 CRITERION= 0.1657E-02
MOMENT CONVERGENCE VALUE = 0.1884E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 48 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7012E-02
DISP CONVERGENCE VALUE = 0.3506E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.3506E-03
FORCE CONVERGENCE VALUE = 0.1642E-01 CRITERION= 0.1661E-02
MOMENT CONVERGENCE VALUE = 0.1794E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 49 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.7519E-03
DISP CONVERGENCE VALUE = 0.7506E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9983 SCALED MAX DOF INC = -0.7506E-03
FORCE CONVERGENCE VALUE = 0.2228E-04 CRITERION= 0.1645E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.7653E-08 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 50 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5368E-02
DISP CONVERGENCE VALUE = 0.2684E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.2684E-03
FORCE CONVERGENCE VALUE = 0.2148E-03 CRITERION= 0.1648E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.7249E-08 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 51 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.3172E-02
DISP CONVERGENCE VALUE = 0.3172E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.3172E-02
FORCE CONVERGENCE VALUE = 0.3346E-03 CRITERION= 0.1761E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1087E-06 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 52 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.8481E-02
DISP CONVERGENCE VALUE = 0.4241E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.4241E-03
FORCE CONVERGENCE VALUE = 0.5817E-02 CRITERION= 0.1769E-02
MOMENT CONVERGENCE VALUE = 0.1035E-06 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 53 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.4289E-02
DISP CONVERGENCE VALUE = 0.2144E-03 CRITERION= 0.2221E-03 <<< CONVERGED
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.2144E-03
FORCE CONVERGENCE VALUE = 0.1141E-01 CRITERION= 0.3537E-02
MOMENT CONVERGENCE VALUE = 0.9862E-07 CRITERION= 0.1657E-03 <<< CONVERGED
EQUIL ITER 54 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.3429E-02
DISP CONVERGENCE VALUE = 0.3373E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9835 SCALED MAX DOF INC = -0.3373E-02
FORCE CONVERGENCE VALUE = 0.3678E-03 CRITERION= 0.1643E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.7866E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 55 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.9355E-02
DISP CONVERGENCE VALUE = 0.4678E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.4678E-03
FORCE CONVERGENCE VALUE = 0.9505E-02 CRITERION= 0.1656E-02
MOMENT CONVERGENCE VALUE = 0.7493E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 56 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.8412E-03
DISP CONVERGENCE VALUE = 0.8366E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9945 SCALED MAX DOF INC = 0.8366E-03
FORCE CONVERGENCE VALUE = 0.7529E-04 CRITERION= 0.1655E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.2898E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 57 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2805E-01
DISP CONVERGENCE VALUE = 0.1402E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.1402E-02
FORCE CONVERGENCE VALUE = 0.4796E-01 CRITERION= 0.1697E-02
MOMENT CONVERGENCE VALUE = 0.2731E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 58 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7182E-02
DISP CONVERGENCE VALUE = 0.3591E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.3591E-03
FORCE CONVERGENCE VALUE = 0.4739E-01 CRITERION= 0.1700E-02
MOMENT CONVERGENCE VALUE = 0.2596E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 59 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1221E-02
DISP CONVERGENCE VALUE = 0.1220E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9988 SCALED MAX DOF INC = -0.1220E-02
FORCE CONVERGENCE VALUE = 0.6585E-04 CRITERION= 0.1658E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1339E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 60 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1121E-01
DISP CONVERGENCE VALUE = 0.5607E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.5607E-03
FORCE CONVERGENCE VALUE = 0.1315E-01 CRITERION= 0.1669E-02
MOMENT CONVERGENCE VALUE = 0.1284E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 61 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2806E-01
DISP CONVERGENCE VALUE = 0.1403E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.1403E-02
FORCE CONVERGENCE VALUE = 0.4517E-01 CRITERION= 0.1712E-02
MOMENT CONVERGENCE VALUE = 0.1237E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 62 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6639E-02
DISP CONVERGENCE VALUE = 0.6958E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.1048 SCALED MAX DOF INC = 0.6958E-03
FORCE CONVERGENCE VALUE = 0.4105E-01 CRITERION= 0.1716E-02
MOMENT CONVERGENCE VALUE = 0.1105E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 63 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1935E-02
DISP CONVERGENCE VALUE = 0.1934E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9996 SCALED MAX DOF INC = -0.1934E-02
FORCE CONVERGENCE VALUE = 0.5929E-04 CRITERION= 0.1647E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.4333E-08 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 64 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1142E-01
DISP CONVERGENCE VALUE = 0.5711E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.5711E-03
FORCE CONVERGENCE VALUE = 0.1569E-01 CRITERION= 0.1660E-02
MOMENT CONVERGENCE VALUE = 0.4189E-08 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 65 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7170E-02
DISP CONVERGENCE VALUE = 0.3585E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.3585E-03
FORCE CONVERGENCE VALUE = 0.2101E-01 CRITERION= 0.1664E-02
MOMENT CONVERGENCE VALUE = 0.3982E-08 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 66 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.7601E-03
DISP CONVERGENCE VALUE = 0.7591E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9988 SCALED MAX DOF INC = -0.7591E-03
FORCE CONVERGENCE VALUE = 0.2725E-04 CRITERION= 0.1645E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1918E-08 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 67 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.3501E-02
DISP CONVERGENCE VALUE = 0.3021E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.8629 SCALED MAX DOF INC = 0.3021E-02
FORCE CONVERGENCE VALUE = 0.9134E-03 CRITERION= 0.1756E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.9663E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 68 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6891E-02
DISP CONVERGENCE VALUE = 0.3446E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.3446E-03
FORCE CONVERGENCE VALUE = 0.4586E-02 CRITERION= 0.1764E-02
MOMENT CONVERGENCE VALUE = 0.9198E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 69 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.3131E-02
DISP CONVERGENCE VALUE = 0.3019E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9642 SCALED MAX DOF INC = -0.3019E-02
FORCE CONVERGENCE VALUE = 0.3051E-03 CRITERION= 0.1649E-02 <<< CONVERGED
EQUIL ITER 70 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1295E-01
DISP CONVERGENCE VALUE = 0.6473E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.6473E-03
FORCE CONVERGENCE VALUE = 0.1622E-01 CRITERION= 0.1662E-02
MOMENT CONVERGENCE VALUE = 0.7134E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 71 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6956E-02
DISP CONVERGENCE VALUE = 0.3478E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.3478E-03
FORCE CONVERGENCE VALUE = 0.2255E-01 CRITERION= 0.1666E-02
MOMENT CONVERGENCE VALUE = 0.6774E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 72 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.8180E-03
DISP CONVERGENCE VALUE = 0.8171E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9989 SCALED MAX DOF INC = -0.8171E-03
FORCE CONVERGENCE VALUE = 0.2990E-04 CRITERION= 0.1644E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1441E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 73 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.9698E-02
DISP CONVERGENCE VALUE = 0.4849E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.4849E-03
FORCE CONVERGENCE VALUE = 0.1305E-01 CRITERION= 0.1657E-02
MOMENT CONVERGENCE VALUE = 0.1372E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 74 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4801E-03
DISP CONVERGENCE VALUE = 0.4793E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9983 SCALED MAX DOF INC = -0.4793E-03
FORCE CONVERGENCE VALUE = 0.1400E-04 CRITERION= 0.1646E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.4189E-09 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 75 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5491E-02
DISP CONVERGENCE VALUE = 0.4187E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.7625 SCALED MAX DOF INC = 0.4187E-02
FORCE CONVERGENCE VALUE = 0.1623E-03 CRITERION= 0.1699E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.3872E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 76 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1132E-01
DISP CONVERGENCE VALUE = 0.5661E-03 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.5661E-03
FORCE CONVERGENCE VALUE = 0.1581E-01 CRITERION= 0.1709E-02
MOMENT CONVERGENCE VALUE = 0.3679E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 77 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.3078E-02
DISP CONVERGENCE VALUE = 0.1539E-03 CRITERION= 0.2221E-03 <<< CONVERGED
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.1539E-03
FORCE CONVERGENCE VALUE = 0.1539E-01 CRITERION= 0.3423E-02
MOMENT CONVERGENCE VALUE = 0.3495E-07 CRITERION= 0.1657E-03 <<< CONVERGED
EQUIL ITER 78 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.7553E-02
DISP CONVERGENCE VALUE = 0.7396E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.9792 SCALED MAX DOF INC = -0.7396E-02
FORCE CONVERGENCE VALUE = 0.3471E-03 CRITERION= 0.1613E-02 <<< CONVERGED
MOMENT CONVERGENCE VALUE = 0.1009E-06 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 79 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.9893E-02
DISP CONVERGENCE VALUE = 0.1082E-02 CRITERION= 0.2221E-03
LINE SEARCH PARAMETER = 0.1094 SCALED MAX DOF INC = 0.1082E-02
FORCE CONVERGENCE VALUE = 0.7101E-02 CRITERION= 0.1628E-02
MOMENT CONVERGENCE VALUE = 0.9268E-07 CRITERION= 0.8285E-04 <<< CONVERGED
EQUIL ITER 80 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2061E-02
>>> SOLUTION NOT CONVERGED AFTER 80 EQUILIBRIUM ITERATIONS
*** LOAD STEP 1 SUBSTEP 69 NOT COMPLETED. CUM ITER = 963
*** BEGIN BISECTION NUMBER 1 NEW TIME INCREMENT= 0.93856E-04Best regards,
Moritz
- The topic ‘Substep does not converge eventough criteria are met’ is closed to new replies.
6785
1331
1147
