June 13, 2020 at 2:47 pm
AmbarNaik13
SubscriberHow can one do force-based sub modelling?
As far as I have seen, a displacement-based sub-modelling can be easily done when coarse and fine models have is a solid body. In the new version of ANSYS, there is a possibility to do force-based sub-modelling. However, the pre-requisite is to have beam elements in the coarse model and the fine model can have shell elements or solid elements. I tried to convert the element, where I want to set up a cut boundary, into beam element, but SpaceClaim gives an error there.
Is there any way how the solid to solid, force-based modelling can be done?
June 18, 2020 at 8:46 pm
Wenlong
Ansys EmployeeHi AmbarNaik,
I am not an expert in sub-modeling, but does this documentation help?
Wenlong
================ Note ====================
If you have trouble opening the links I attached, please see the first useful link below
Useful Links
- How to access Ansys Online Help Document
- How to show full resolution image
- How to use Google to search within Ansys Student Community
- The topic ‘Sub-modelling – force based’ is closed to new replies.
6550
1311
