May 17, 2024 at 8:44 am
Yahia
SubscriberHi everybody;
Can Ls-Dyna solver in Ansys free student version be employed to solve a model in LS-OPT?Â
Thanks
May 21, 2024 at 6:33 am
igandiko
Ansys EmployeeHi, you can call any solver, command, or script in ls-opt. Please make sure you define ls-dyna solver command correctly in LS-OPT stage definitions. I would first run ls-dyna in batch mode through command terminal and use the same command in ls-opt stage.Â
- The topic ‘Student verion solver’ is closed to new replies.
