January 23, 2025 at 8:08 pmlworrBbp_participant
So I am trying to perform an analysis on asteel plate where a pressure force is applied in a specific part of the plate but every time I try and draw a circle to indicate where the pressure should go, it gives an error saying that pressure is located on a surface body and will be ignored and I dont know how to make the simulation only have the pressure in that one area Â
January 23, 2025 at 8:53 pmErik KostsonAnsys Employee
Hi
Can you give some details , say images showing the geometry the bodies/parts in the tree, the loads applied etc.? So as much information as possible.
All the best
Erik
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Inventor 2025 files
- SpaceClaim stops sharing topology
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- solidwork parameters for optimization in ansys
635
599
591
366
