February 20, 2025 at 9:26 am
harryo
SubscriberHello!
I am using Ansys 2024 R1, trying to do some Structural Optimization to save som weight in a given geometry from a company. I get the error "The optimization solution run was terminated. Check the Solver Output on the Solution Information object for possible causes". I also have problem that i get geometry that is not possible to manufacture, but i still want to remove material if it is unecessary. Any tips?
February 21, 2025 at 10:50 am
Ashish Khemka
Forum ModeratorHello,
Please check if the following links help:
ANSYS Workbench – Mechanical – Topology Optimization – MAPDL Error
Ashish Khemka
Ansys Innovation Space
- NA
- Response constraint not allowing structural optimization to solve.
- Protected Depth Topology Optimisation
- how to get stress at a node and put it in a parameter for use with optimization
- Add Parameter so existing set
- optislang tutorial: damped oscillator calibration
- OptiSlang does not create LsxDefs while importing LS-DYNA output
- Feasibility Check – FT Sensor Flexible Chassis Design Optimization
- Issue with Reaction Force Scaling in ¼ LS-DYNA Model Simulation
- OptiSlang sensitivity analysis can’t assign different values to the parameters
1013
956
858
797
