TAGGED: ansys-mechanical, ansys-workbench, apdl, mechanical-apdl
January 10, 2022 at 9:02 am
BassaSelim3
SubscriberHi to everyone,
I am using mechanical workbench. Is it possible to save a string with more than 32 characters in an APDL block? In the command reference 32 is the maximum:
For example I want to save the string :
C:UsersansysDesktopModellTestvariante1variante2variante3
as the parameter 'path'
I tried this:
path='C:UsersansysDesktopModellTestvariante1variante2variante3'
but it didn't work.
With 32 characters or less it works fine
Thank you all in advance
Regards
Bassa Selim
January 10, 2022 at 12:12 pmAshish Khemka
Please see if the following link helps:
Manipulating Text Strings in ANSYS Mechanical APDL ÔÇô PADT, Inc. ÔÇô The Blog (padtinc.com)
Regards Ashish Khemka
January 14, 2022 at 12:56 pmBassaSelim3
SubscriberHi Ashish thank you for the anwer. I could solve my problem with your link.
Regards Bassa Selim
Viewing 2 reply threads- The topic ‘String Parameter with more than 32 characters’ is closed to new replies.
6570
1311
