September 17, 2022 at 4:38 pm
jccubi
SubscriberI am running Ansys Workbench 2022 R2 in two computers and I noted that the stress-strain curve for bilinear isotropic hardening is missing (only stress-temperature is shown). Picture below is ucnluded for clarity. Besides, an "Active Table" appears in the window of material properties but no idea what this means.
I would appreciate any help on this regard. Thanks in advance
September 19, 2022 at 12:53 pm
Aniket
Forum ModeratorThanks for your feedback! This erroneous behavior is fixed in 2023R1.
-Aniket
September 25, 2022 at 5:18 pm
jccubi
SubscriberThank for your response. I understand that 2023R1 will be available next year, isn´t it?Â
April 12, 2023 at 2:08 pm
April 12, 2023 at 8:21 am
XIAOWEN LI
SubscriberHello, i have the same question as Jccubi in 2023R1. I don't know why the "Active table"Â can't be changed from "Plastic" to "Total" but the reverse is possible. And why it has been setup in the new version? It is for what?
Thank you for any reply.
April 12, 2023 at 2:25 pm
Aniket
Forum ModeratorThe active table is read-only now set to plastic, and only shows plastic part of the stress strain curve.
-Aniket
June 1, 2023 at 6:23 am
casper.kruger
SubscriberDoes this effect the solver or is it a graphical issue only?Â
June 2, 2023 at 12:30 pm
Aniket
Forum ModeratorNo, it is simply showing the plastic part of the curve instead of total. No changes to solver.
-Aniket
June 14, 2023 at 2:50 pm
Emanuel Santos
SubscriberI am using the same command in the 2023R1 student and I get the same thing, but the plastic part shows that it is an inclined line, I want to modify the elastic part of the material by adding 250 MPa and 100 MPa of young's modulus, but the graph does not indicate that.
previous versions:
current version:
I don't know why in the plastic part of the graph it appears with an inclination.
- The topic ‘Stress-Strain Curve Missing’ is closed to new replies.
4838
1587
1386
1242
