February 13, 2021 at 7:40 am
hari123
SubscriberHow to perform stress linearization in shell body ANSYS V19.0. (When I select above mid surface node, It's by default selecting mid node, same in bottom)n -
February 15, 2021 at 7:16 pm
danielshaw
Ansys EmployeeYou can linearize along a multiple shell elements, but you cannot linearize through the thickness of a shell element. The results on the top and bottom of the shell element are essentially the linearized results.nn
- The topic ‘Stress Linearization in Shell Bodies’ is closed to new replies.
