February 28, 2024 at 9:08 am
Gregor Todd
Subscriber -
February 28, 2024 at 10:09 am
Aurojyoti Prusty
Ansys EmployeeHi,
You may follow the discussion and the references provided in below link for calculating stress intensity factors.
/forum/forums/topic/stress-intensity-factor-2/
Hope this helps.
Thanks,
Aurojyoti
February 28, 2024 at 10:58 am
peteroznewman
SubscriberHi Gregor,
You show a plot of Stress Intensity. Equivalent (von-Mises) Stress is more commonly used to evaluate whether a ductile material has exceeded its Yield Strength. Why did you plot Stress Intensity?
Stress Intensity is different from Stress Intensity Factor (SIF) which is a term related to failure due to the presence of a crack. Do you have a crack you want to analyze?
To get accurate stress results, you need more than one element through the wall thickness. A minimum of two is recommended and more elements through the thickness is often used to obtain a more accurate value of peak stress.
- The topic ‘Stress Intensity’ is closed to new replies.
6019
