January 12, 2021 at 10:09 am
Panos_Ai
SubscriberHello, I am creating this geometry (figure 1) with Polyline and then Extrude.
The issue is that when I solve the pressure load (figure2) the deformation is very strange (figure 3) as if it considers some boundary in the points.
Any suggestions ?
January 12, 2021 at 6:40 pmuser deleted
Subscriber,good evening!nAt the beginning: it is necessary to know, where are the supports? nI think, that your issue can be related to the following situation: to create Polyline, you have created a lot of points:n
And now you applied boundary conditions for all these points. nIt seems like your issue is related to these points.n
Viewing 1 reply thread- The topic ‘strange deformation under variable load’ is closed to new replies.
4673
1565
1386
1231
