Steady State Thermal vs Transient Thermal Difference?
    • BeEazy
      How is the transient period of a Steady State Analysis system different from an explicit Transient State Analysis system? In my Steady State temperature graph, there is a brief transient period where the temperature oscillates in the first ~20 seconds:
      Steady State
      However, when I run a Transient Analysis system with the same setup, the first 5 seconds look completely different:
      Transient State
      So what is the main difference between the two analysis systems?
    • Sai Deogekar
      Hi,nThat seems a bit strange! Transient thermal analysis considers the thermal capacitance of a material (also known as thermal inertia), while Steady State analysis only considers the Thermal Conductivity and ignore the Capacitance. So if you do a Transient Thermal analysis for a long enough duration, its solution should match with the Steady-State Thermal Analysis.nI am not sure why you are getting the results that you do. Could you share the geometry and the boundary conditions in your problem?nThanks,nSain
  • The topic ‘Steady State Thermal vs Transient Thermal Difference?’ is closed to new replies.
