July 8, 2026 at 9:42 am
ggege0524
SubscriberI am working on a model in ANSYS Mechanical where I need to perform two separate Static Structural analyses.
In the first analysis, I establish an initial stress state and deformation of the specimen. In the second analysis, I modify the model (e.g., by introducing a crack), and I would like to use the stress state and deformed geometry from the first analysis as the initial condition.
The issue is that I cannot find a way to transfer the solution data (stress, strain, deformation, etc.) from one Static Structural analysis to another. I have considered using a multistep analysis, but since the model geometry/mesh changes between the two analyses, that does not seem to be a suitable approach.
Is there a recommended workflow for transferring both the stress state and the deformed geometry from one Static Structural analysis to another when the model has been modified between analyses?
July 9, 2026 at 9:02 am
peteroznewman
SubscriberYou can’t have the same stress state in a model with a crack as you had in a model without a crack.
You can have the same loads and supports on each model (one without a crack and one with a crack) and get two different stress results. Each model can solve independently.
Fatigue cracks can grow from a tiny initial crack and become a big crack over many load cycles. Ansys has some crack growth models. Is this what you are interested in?
6835
1343
1152
