February 29, 2024 at 11:01 am
Jörg Rademann
SubscriberDear Sir or MadamÂ
I am trying to start a coupling simulation between MADYMO and LSDYNA.Â
I have the Ansys LSDYNA version v221 and the MADYMO version 2020.2.Â
I have prepared everything so far, but then I get a license error.Apparently, according to the help, this simulation type only works with LSDYNA version R9.70 .
Could you provide this version or is there another way to fix the error?
Many thanks and best regardsÂJörg
March 4, 2024 at 2:18 pm
George Karnos
Ansys EmployeeI believe this is a Madymo license error, not an ANSYS License error.
Does LS-DYNA start on it's own?
If not, under %TEMP%\.ansys you should see licedebug out files.
Check the one for ls-dyna for errors and post the error.Usually the error: does not support this version for this feature mean that the license file'sÂ
increment for the feature has a version limiting date on it.
- The topic ‘Starting Coupling Simulation LSDYNA – MADYMO’ is closed to new replies.
5969
1307
