September 22, 2019 at 5:49 pm
September 22, 2019 at 7:46 pm
peteroznewman
SubscriberYou already have an acceleration load. Just add the acceleration due to gravity to that load.
September 23, 2019 at 3:59 am
rahulranjan1995
SubscriberHello Peteroznewman sir,
I have one doubt, suppose I open static structural module and apply line pressure on a beam and then link transient structure module with static structure and apply acceleration over the beam. Then will the line pressure get overlap in transient structure module as well?
September 23, 2019 at 1:02 pm
peteroznewman
SubscriberNo.
Just use Transient Structural, but use 3 time steps and turn off Time Integration in the first step when you apply the acceleration due to gravity.
The transient load is applied in step 3 with Time Integration turned on.
September 23, 2019 at 2:18 pm
rahulranjan1995
SubscriberBy going through your previous suggestions on another post of mine I tried working on perforated steel beam of I section using mid-surfacing but when I did modal analysis on that model the natural frequency of all the modes came out to be zero. Can you explain the reason?
September 23, 2019 at 4:05 pm
peteroznewman
SubscriberYou didn't add a Fixed Support to one end of the beam in Modal, which needs its own support unless you link the Solution cell of a Static Structural into the Setup cell of Modal in Workbench, then you are not allowed to add a Fixed Support to Modal.
- The topic ‘Standard earth gravity’ is closed to new replies.
6660
1313
.jpg?width=690&upscale=false)
