October 6, 2023 at 5:04 pm
Frederico Ricca
SubscriberHello, I'm a master's student currently working on my thesis. My job is to find a numerical tool capable of simulating the squeeze flow of an adhesive fluid when it is pressed by a moving substrate against a fixed substrate. I know that the speed could be something like 0.1 mm/s. The initial thickness should be 2 mm and the final thickness should be 1 mm. My question is, do I need to run an FSI simulation or can I just use fluent? If so, what steps will the solution take? What could be the boundary conditions? Thank you!
October 9, 2023 at 11:03 am
Forum ModeratorAssuming the two plates aren't deformed by the fluid then Fluent with VOF will work. You will need moving mesh to simulate the squeezing effect.Â
- The topic ‘SQUEEZE FLOW’ is closed to new replies.
Ansys Innovation Space
971
858
851
792
