October 28, 2024 at 1:34 am
nuraqilahzahari155
Subscriberhai, i have tried run simulation on ammonia and gasoline spray using DPM model in ansys fluent, but the results for both spray in terms of spray angle, penetration length and spray pattern are same. How to solve this problem?
The setting for turbulence model i used standard k-epsilon. Type of injector i used plain orifice atomizer. Boundary condition i set velocity inlet with 200 m/s, pressure outlet 3000000 pa. I run this simulation in transient state, pressure-based solver.
The mesh is shown in figure below -
October 29, 2024 at 8:43 am
SRP
Ansys EmployeeHi,
I suggest you to take a look at the tutorial to check the setting for your setup: Chapter 21: Modeling Evaporating Liquid Spray
I hope that helps you.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
1495
1386
1209
