Photonics
Photonics
spontaneous four-wave mixing (detailed calculation of squeezing level)
    • Farzaneh Shayegan
      In your recent example about spontaneous four-wave mixing, a microring resonator has been modeled. The biphoton wavefunction and squeezing have been calculated. For calculating the squeezing level, what formula have been used?
      Is it possible to update the webpage related to this example, and give more detail about the calculation and important parameters like repetition rate or pump power. I want to check the accuracy of the used formula and compare that with the papers given in this field.
    • Kyle
      Hello, thank you for the question. I will discuss this with the author of this article and get back to you.
  • The topic ‘spontaneous four-wave mixing (detailed calculation of squeezing level)’ is closed to new replies.
