May 24, 2020 at 8:59 am
mdsaifansari
SubscriberHi Everyone,
I want to hold the pressure vessel externally from support running through the circumference. The way one grabs the water bottle from the hand. To do so, I want to split the round face, and I am unable to do so.Â
I tried splitting the body, but it is not primarily what I want because it won't be a continuous body at all.Â
Please help me as it will be putting a halt on my project. -
May 25, 2020 at 2:21 pm
peteroznewman
SubscriberIn SpaceClaim, you can use the Split button and select a Plane and a Face to split that face with that plane to create two faces on one solid.
This is different than using Split Body, which creates two solids.
- The topic ‘Splitting a cylinder surface in two faces axially’ is closed to new replies.
