January 12, 2025 at 4:58 pmKesselleSubscriber
how do i get a spiral pattern instead of circular ?
January 13, 2025 at 6:10 amKeyur KanadeAnsys Employee
You can create spiral pattern.
For this you will need to create helix using Pull command. This will give you Tragectory while using Move tool. While using Move tool, use this Tragectory and use Create Pattern option on the left side.Â
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
599
591
555
366
