February 19, 2026 at 9:24 am
amirhossein.nikpour
SubscriberHello,I am currently modeling a water-filled vessel in LS-DYNA.ÂThe vessel structure is modeled using shell elements, and the water is modeled using SPH particles. The vessel is subjected to earthquake records.ÂThe adopted dimensions are ton-mm-s-NÂThe issue I am encountering is that the water appears to compress excessively ( please see the video)ÂEOS_MURNAGHANK=2200ÂGAMMA= 7ÂSPH SECTIONCSLH 1.2HMIN 1ÂHMAX 1.1ÂSPH CONTROLIDIM 1NMMNEIGH 250FORM 15MAXV 0ÂBODY LOAD Y WITH DRÂSph mass 17.3 tonSph particle mass 0.0032 tonNumber of sph particle 5409ÂSph materialÂ09- NULLRO 1.000e-09ÂMU=0ÂAutomatic node surface contactSFSA= 2FSSB= 1SOFT= 1SOFSC= 0.1ÂÂI would appreciate it if you could share your recommendations on how to resolve this issue.Thank you in advance for your support. -
February 19, 2026 at 11:14 am
ErKo
Ansys EmployeeÂ
Hi
I think SPH is not going to be very good/easy for this (pressure distribution is hard to get right even for just static water – so even hydrostatic pressure can be very hard) – others might comment here.
Perhaps I would suggest ALE or ICFD aproaches instead – there are some papers on these 2 if you search online (sure you know about this one) . E.g.:
Analytical and Numerical Studies of Seismic Fluid-Structure Interaction in Liquid-Filled VesselsÂ
Perhaps other members might have some experience with this type of analysis, so wait for feedback – hope this helps
Erko
1306
