LS Dyna
LS Dyna
SPH Node To Beam element Contact
    • WooMin Jang
      Hi I'm modelling for Debris flow with SPH and Sturcture with Beam element
      I used ''CONTACT_AUTOMATIC_NODE_TO_SURFACE && _General'' and SOFT=1 contact
      but there's no error occured but no interaction happended between them.
      In case i used contact_beams_to_surface, there happens error message 'cannot find element of master segments'
      How can i solve it?? and In manual, it seems to be uncertain what can i use for this contact..
      Please let me know
      Thanks in advance
    • Ram Gopisetti
      Hi
      Have you tried single surface contact ?
      Cheers ram.
      • WooMin Jang
        Sure but there's nothing changed..
        I have a question
        In LS-DYNA, how beam element's thickness can be considered?
        I think the error message 'cannot find element of master segments ' gives me some hint that
        in the model, beam element have no thickness to be contacted
        I double checked 'section_beam' and the thickness is rightly input.
    • Andreas Koutras
      It seems the current contacts do not account for node-to-beam contact. An alternative is to wrap the beams with null shells and use the node-to-surface contact between the sph nodes and the null shells.
      • WooMin Jang
        I've researched for this few days.
        I understand that this method is used with mat_null and shells,
        just for contact and cannot reflect bi-linear behavior of material right?
    • Loic Ivaldi
      You should try the DEM method instead of SPH. With DEM you have a keyword to allow coupling : *DEFINE_DE_TO_BEAM_COUPLING.
      As stated by @Andreas I don't think node-to-beam contact is available.
      Best,
      LoĂŻc
      • WooMin Jang
        Thanks!
        But could you let me know the reason why SPH cannot contact with beam but DEM can??
        • Loic Ivaldi
          Probably a feature not as necessary in SPH as in DEM
          SPH is for modeling a continuous medium whereas DEM is intented for granular materials where it's more common to pass through a sieve or grid therefore a coupling between DEM and beam is needed
  • The topic ‘SPH Node To Beam element Contact’ is closed to new replies.
