3D Design
3D Design
SpaceClaim to DesignModeler
    • sivelina
      Hello!
      1.I have a geometry model drawn on SpaceClaim.  I want to import it into  DesignModeler. In what format should the geometry model file be saved?
      2. I have a geometry model drawn on SpaceClaim and saved in format ".scdog".What is the next step to convert to Mesh?
    • Keyur Kanade
      From SpaceClaim you can export neutral format like step iges or parasolid and then import it in DM. If you have student license, please check the formats allowed.
      From SpaceClaim you need to go to Ansys Meshing or Fluent Meshing to generate a mesh for geometry.
      Please check following videos
      Ansys Meshing Sizing:
      https://www.youtube.com/watch?v=w4q6q8nKF3U
      Fluent Meshing Watertight Workflow:
      https://www.youtube.com/watch?v=aBxbYRVoRLo
      Ansys Meshing: Meshing Methods:
      https://www.youtube.com/watch?v=nEOC8rDnnRo
      Please go through help manual for more details
      Keyur
    • amol.kumbhar
      You can also open same file in DM from workbench environment.
  • The topic ‘SpaceClaim to DesignModeler’ is closed to new replies.
