July 8, 2020 at 11:00 am
Vishalgarg474
SubscriberHello everyone,
I have a problem while meshing a 2d geometry in the spaceclaim mesh tool.
For example: Let's say, I have developed a whole 2D axi-symmetric geometry and I move on to do the meshing, and have already done some mesh on certain faces. But now, I detect that there a bit of problem in the sketch. I went back to the design tool and made the changes in the geometry (some other face which I did not mesh before), now when I go back to the mesh tool, all the previous mesh that I have made on other faces are lost and I have to start from scratch. Is there a solution to retain the mesh of the other faces or what could i be doing wrong?Â
Thank you in advance. -
July 8, 2020 at 3:09 pm
Aniket Chavan
Forum ModeratorPlease check:
Compare parts on update option:Â https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/ref_cad/cadComparePartsOnUpdate.html
And set it to associatively. This will take more time to import the model in Mechanical, but would compare the other parts before bringing to Mechanical retaining most of the original mesh.
Another way is using Model assembly, if you have one part which will be frequently modified in the model, using two subassemblies. more info at:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb_sim/ds_mesh_mod_examples.html
Regarding SpaceClaim meshing documentation visit:
And finally if for combining two surface bodies with internal edges, use the Stitch tool under repair instead of combine tool under design.Â
-Aniket
How to show full resolution image
How to use Google to search within Ansys Student Community
- The topic ‘SpaceClaim Meshing’ is closed to new replies.
5899
1306
