January 17, 2025 at 10:33 ammatthieu.rouillierSubscriber
I work in the IT department and a user has the error “FNE activation failed” on her version of spaceclaim 2024.I've referred to several sections on your site, but the solutions you suggest above haven't solved the problem...
Here are the sources of the solutions I tried:
FNE activation Error
FNE Activation Failed. Peer certificate cannot be authenticated with given CA certificates | Ansys KnowledgeDiscovery SpaceClaim License Activation Error
Can you help me please ?
January 29, 2025 at 1:52 pmGeorge KarnosAnsys Employee
Hello Mathieu,
Are you using shared web licensing or do you have a physical license installed on a machine
at your location?
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Inventor 2025 files
- SpaceClaim stops sharing topology
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- solidwork parameters for optimization in ansys
635
599
591
366
