March 29, 2024 at 6:35 pmChuan ZhongSubscriber
Dear Staff Member at Lumerical,
Could you give me some recommendations on what type of source I could use to model the transmission of an omnidirectional LED source, thank you.
Best wishes
Chuan
April 1, 2024 at 6:45 pmGuilin SunAnsys Employee
If your LED is layered, thin-file type, I would suggest to use stackdipole:Â
FDTD vs stackdipole - halfspace emission in a multilayer stack
Usually it uses dipole source for simulation, and average the results with 2 or 3 dipole sources separately, depending on if the LED has symmetry.
Please refer to this example  Micro-LED
- The topic ‘Source to model light extraction from an omnidirectional LED’ is closed to new replies.
Ansys Innovation Space
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Help for qINTERCONNECT
- Trapezoidal ring
- Issues with getting result from interconnent analysis script
- Topology Optimization Error
- Edge Coupler EME Example Issue
- How to measure transmission coefficients on a given plane .
543
523
225
209
