July 26, 2024 at 8:06 am
Markus Ratzke
SubscriberVersion 2024 R2 (maybe also R1.3): Geometrical properties of a source cannot be changed using the properties dialog, all numbers revert to the standard values. However, dragging the object is possible.
Is this a bug?
July 26, 2024 at 3:51 pm
Guilin Sun
Ansys EmployeeYes it is a bug. Please use script to set or use mouse to move. Sorry for the inconvenience .
July 29, 2024 at 9:26 am
Markus Ratzke
SubscriberWe have another problem (R1.3): Sweeps are not running as expected – individual simulations are run but the “master” simulation is complaining about not being able to read the assigned output (wrong size)…
July 29, 2024 at 3:21 pm
Guilin Sun
Ansys EmployeeThis is mostly due to another issue: are you sweep geometry or simulaiton span and monitor field result? if so, the matrix does not work. YOu will need to use fixed mesh size and mesh points during the sweep.
If this does not resolve the issue, please give the screenshots and the error message.
- The topic ‘Source position in FDTD cannot be changed’ is closed to new replies.
6685
1313
