August 30, 2023 at 6:58 pm
TingWangUNO
SubscriberHi,
I was trying to simulate a case where steam will be injected to a 3D rotating cylinder and the steam will be condensed and the water will be removed through a outlet. For that reason and for a simple calculation, at first, I want to simulate this thing in 2D. In a 2D circular domain steam will be injected through a source term and after condensation the water will be removed through a sink term. I am trying to use all the mass, momentum and energy source. Both source and sink terms contain water and vapor. IÂ am building the source and sink term by defining Named Expression.
When I am trying to input all mass, momentum and energy source and sink terms, It is showing that "Internal error: too many profiles."
When I am using only mass and momentum source and sink terms, the case is running but there is no progress even after 2/3 days.
So, what can I do in this case? Can you please suggest something how I can define the source and sink terms for this case?Â
Thank you,
Ting Wang's Research Group -
August 31, 2023 at 3:08 pm
Forum ModeratorI've seen this before, but can't remember the root cause. Which version of Fluent are you using?Â
August 31, 2023 at 11:53 pm
TingWangUNO
SubscriberThank you for your reply.
I am currently using Workbench 2021 R1.
September 1, 2023 at 10:56 am
Forum ModeratorOK, that may explain it. Expressions have been improved significantly since being added to the code so whatever caused the issue is likely to be been fixed in 21R2 or 22Rx. Current release is 2023R2. I'd also advise running models in Fluent standalone (open via the Windows Start menu) unless you need the parameter tools.Â
- The topic ‘Source and Sink term in 2D Domain’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4592
1494
1386
1209
