Ansys Gateway powered by AWS
Ansys Gateway powered by AWS is the solution for developers, designers, and engineers who want to manage their complete Ansys Simulation & CAD/CAE developments in the cloud.
Some % of RAM filled message when running Fluent
    • Mark O
      When running Fluent you may see a message that some % of the RAM is filled. A typical message may look like
      WARNING: Rank:0 Machine ######## has 11 % of RAM filled with file buffer caches.This can cause potential performance issues. Please use -cflush flag to flush the cache.
      Such messages are quite common on linux machines. The advice to use -cflush on the fluent command line rarely makes any difference.  It is an MPI issue in which MPI makes use of the /dev/shm file system for its shared memory mode implementation and it doesn't always clear out the memory leaving files that can only be deleted by root. It is not normally a problem unless the RAM gets very full. In which case the simplest thing is to reboot the machines since a reboot always clears out /dev/shm
Viewing 0 reply threads
  • The topic ‘Some % of RAM filled message when running Fluent’ is closed to new replies.
