Preprocessing
Preprocessing
Solver Input File 1
    • NRNordy
      While trying to run an analysis on Icepak, I keep getting this message:
      "Failed to generate solver input file 1"
      I'm not sure what to do at this point. I've tried editing the analysis parameters, generating various meshes, and nothing works. Does anyone know what this message means?
    • Nikhil Tamhankar
      Hi Does you AEDT Icepak design contain any link to HFSS 3D layout for a PCB component or any other link ? If yes, please check if the link is established correctly or not by creating it again if necessary.
    • NRNordy
      No, there is no link to any HFSS 3D layouts. I directly imported an assembly model from Solid Edge, simplified it, and have been attempting to run the simulation on it from there. I just imported it as a .step file, I don't know if that makes a difference
  • The topic ‘Solver Input File 1’ is closed to new replies.
