November 21, 2020 at 11:52 am
Ruk
Subscriberhello to allnnI'm doing an unsteady simulation for the delta wing in the Fluent. I compared PISO and SIMPLE-C algorithms in this investigation. Since Fluent offers to use the PISO algorithm for transient flow but the solution was diverging for this algorithm and the system gave a floating-point error. In contrast, the solution was convergent in the SIMPLE-C method. I don't know why the PISO algorithm is inefficient at this unsteady project (Contrary to Fluent's suggestion). Time step adjusted about 0.0002 s. I used to see the same question in a different place but I did not get the right answer.nnAlso, when I used Extrapolate Variables the solve was diverging for both algorithms.nnplease guide me.nnThanksn -
November 23, 2020 at 1:13 pm
Amine Ben Hadj Ali
Ansys EmployeeMight be due to the fact that URF's of SIMPLEC are bit conservative. Which version are you using?n -
November 23, 2020 at 2:55 pm
Ruk
SubscriberI'm using ANSYS 17.2. I checked the URF values of SIMPLE-C and PISO. There isn't any different between them.n -
November 23, 2020 at 5:12 pm
Amine Ben Hadj Ali
Ansys EmployeePiso has two pressure corrections steps. So even if using same exposed URFs the numerical method is different: can u check if the behavior is reproducible with a supported version. What else are you modeling?n -
November 23, 2020 at 5:19 pm
Amine Ben Hadj Ali
Ansys EmployeeAlso what happens if you disable skewnes corrections?n
Viewing 4 reply threads
- The topic ‘Solve divergence for the PISO algorithm in unsteady solution (ANSYS FLUENT)’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
1495
1386
1209
