May 13, 2020 at 6:00 am
ADTTT
SubscriberI have been having some problems with solving a wheel and hub assembly. Initially I thought it was an issue with having not enough RAM, I only have 8GB available unfortunately.
I reduced the mesh from 2,000,000 Nodes and 800,000 elements to 540,000 nodes and 342,000 elements.
After drastically reducing the mesh and no longer seeing and errors. The solution would fail due to this error:
 ********** CURRENT DISK AND DIRECTORY USAGE **********
 Volume in drive C is OS
 Volume Serial Number is 40D3-6139
 Directory of C:UsersandreDocumentsTitomicTest 1 - 12.05.20_ProjectScratchScr5C95
13/05/2020Â 03:47 PMÂ Â
13/05/2020Â 11:19 AMÂ Â Â Â Â Â Â Â Â 0 ANSYSFatalError.log
13/05/2020Â 11:19 AMÂ Â Â Â Â Â Â Â Â 0 ANSYSTraceBack.log
13/05/2020Â 03:43 PMÂ Â Â Â Â Â 83,320 CAERep.xml
13/05/2020Â 03:43 PMÂ Â Â Â 107,657,511 ds.dat
13/05/2020Â 03:49 PMÂ Â Â Â Â Â Â Â 26 ds_file.stat
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â Â 115 ds_file.xml
13/05/2020Â 03:43 PMÂ Â Â Â Â Â Â Â 70 dummy.dat
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â Â 78 file.bat
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â 7,345 file.cnd
13/05/2020Â 03:45 PMÂ Â Â Â Â Â Â Â Â 0 file.DSPmatK
13/05/2020Â 03:45 PMÂ Â Â Â Â Â Â Â Â 0 file.DSPstack
13/05/2020Â 03:45 PMÂ Â Â Â Â Â Â Â Â 0 file.DSPsymb
13/05/2020Â 03:45 PMÂ Â 10,327,709,184 file.DSPtri
13/05/2020Â 03:45 PMÂ Â Â Â Â Â Â Â Â 0 file.DSPtriU
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â Â Â 0 file.emat
13/05/2020Â 03:45 PMÂ Â Â Â Â Â Â 2,729 file.err
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â Â Â 0 file.esav
13/05/2020Â 03:45 PMÂ Â Â Â 915,275,776 file.full
13/05/2020Â 03:44 PMÂ Â Â Â Â Â 814,970 file.ldhi
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â Â Â 0 file.lock
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â Â 10 file.log
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â Â Â 2 file.mntr
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â Â Â 0 file.osav
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â Â Â 0 file.page
13/05/2020Â 03:44 PMÂ Â Â Â 289,210,368 file.rdb
13/05/2020Â 03:44 PMÂ Â Â Â Â Â Â Â Â 0 file.rst
13/05/2020Â 03:49 PMÂ Â Â Â Â Â Â Â 160 file.stat
13/05/2020Â 03:43 PMÂ Â Â Â Â Â 37,130 MatML.xml
13/05/2020Â 03:43 PMÂ Â Â Â Â Â Â Â 632 SecInput.txt
13/05/2020Â 03:49 PMÂ Â Â Â Â Â 47,646 solve.out
       30 File(s) 11,640,847,072 bytes
        2 Dir(s)        0 bytes free
 *** ERROR ***              CP =   500.719  TIME= 15:50:20
 An input/output error has occurred on the process with MPI Rank ID = 0.Â
 Please check to see if the disk is full.               Â
 NUMBER OF WARNING MESSAGES ENCOUNTERED=     8
 NUMBER OF ERROR  MESSAGES ENCOUNTERED=     1
 ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
I'm not sure what the issue is because I have 20GB available on my SSD.
Cheers,
September 27, 2020 at 2:41 pm
AmbarNaik13
SubscriberEven I am facing the same issue.nncould you please shed some light on this issue?n -
September 27, 2020 at 4:13 pm
peteroznewman
SubscribernThe solver ran out of disk space.nOne of the files was 10 GB and it probably needed another 10 GB but it couldn't get that so it terminated with that error.nFEA jobs, especially transient models, need a lot of free disk space (and RAM). It is best to install a separate SDD of at least 512 GB and only save the current analysis job on that.nThere are ways to reduce the disk usage, such as turning off Output that you don't need, such as Strain. That can be done under Analysis Settings.n -
October 2, 2020 at 12:07 am
mrife
Ansys Employee@AmbarNaik13 & please see the following Help section: Help -> Mechanical APDL -> Performance Guide -> Chapter 4 Memory Usage and Performance.nThere are three sections on the different solvers (sparse, pcg, modal) that discuss the memory and drive space needed in terms of total degrees of freedom. And be sure to read the notes section below the table as it gives scale factors based on element formulation and model type. For example the rules-of-thumb are given for low order solid elements; then scale factors given for high-order solids. Or beam/shell elements. nThese rules assume sparse matrices; some FEM techniques will result in dense regions in the matrices (dense as in the terms are non-zero). This can greatly increase the needed amount of memory or drive space. A usual suspect is a remote point scoped to a region of many nodes.nI think you will find that 8 GB of memory and 20 GB of disk space is just very, very small amounts. Especially for todays auto-mesh algorithms that can create high node count meshes quickly and efficiently. You may be able to solve the model by implementing some mesh size controls to reduce the node count further.nMiken
- The topic ‘Solution Failure: An input/output error has occurred on the process with MPI Rank ID = 0’ is closed to new replies.
5874
1306
