October 23, 2018 at 1:33 am
tomcojocar
Subscriber When CAD Configuration Manager is run, it saysÂ
Prerequisites ..... Configure Success
SWÂ Workbench PlugIn ..... Configure Failed -- Registration Error
In the corresponding log file the only part that seems to be out of order isÂ
SW Registration ExitCode 3Â -- expecting 0
___________________________________________________________________________
ReadPackageInstallData succeeded.
SpaceClaimEngineering Not Detected
October 23, 2018 at 1:42 am
Karthik Remella
AdministratorHello,
Which version of ANSYS is this - R19.2? Also, is this an Academic license?
Have you tried to import the SolidWorks file directly into SpaceClaim?
Thank you.
Best Regards,
Karthik
October 23, 2018 at 1:45 am
tomcojocar
SubscriberThis is AIM 19.1, a student license.
October 23, 2018 at 2:02 am
Karthik Remella
AdministratorHello,
SolidWorks plugin is not included as a part of the student license. Student license will accept neutral CAD formats.
A workaround is to open the SW geometry directly in SpaceClaim. Another way would be to use SW to convert the CAD file to neutral file formats and import in SpaceClaim.
I hope this helps.
Best Regards,
Karthik
October 23, 2018 at 2:05 pm
Sandeep Medikonda
Ansys EmployeeIn addition to what Karthik has said, You might find this information from the help useful.
Sandeep -
October 24, 2018 at 12:54 am
October 24, 2018 at 1:12 am
peteroznewman
SubscriberIn SolidWorks, File, Save As Parasolid.
Either in SpaceClaim, File, Open.
Or in DesignModeler, File, Import External Geometry File.
December 18, 2019 at 5:29 pm
ukijo
SubscriberIf you possess the student version and you want to import a Solidwrorks part/assembly into ANSYS, you just have to save your solidworks part/assembly as a .igs extension and then import it into spaceclaim.
when your part is imported inside spaceclaim save it as a spaceclaim file. Return to workbench and then you import the spaceclaim you just saved, that should work.Â
December 18, 2019 at 7:27 pm
peteroznewman
SubscriberWhile an .igs file will work most of the time, a Parasolid file has a more reliable transfer of complex geometry.
If you use SpaceClaim, you don't even need to save as Parasolid, it will open the SolidWorks file directly.
- The topic ‘SolidWorks CAD Configuration error’ is closed to new replies.
- FSAE CFD – Lesson 1 Preparation question (Using Discovery)
- Add-in Error Excel
- Missing SubDivWrapper.dll
3892
1414
1241
1118
1015
