April 1, 2023 at 3:26 pm
Tejas Prajapati
SubscriberCan some help me in CFD part in solid desiccant dehumidifier.Â
for selecting model conditions in k epsilon equation.inlet conditions
outlet conditionsÂIn this analysis relative humidity also used.
also how I selected porous media for materialÂ
April 4, 2023 at 1:07 pm
Nikhil Narale
SubscriberHello,Â
I apologize, but I am having difficulty fully comprehending your question. However, if you are looking to model porous media, you can designate a specific zone/region as porous within the cell zone conditions. It is important to ensure that the appropriate values for parameters such as inertial resistance, viscous resistance and much more, are properly defined for the porous media.
April 4, 2023 at 1:18 pm
Tejas Prajapati
SubscriberI can explainÂ
I have only two dataÂ
- Inlet temperature 301.05 k
- Relative humidityÂ
Here have a hexagonal shape pipe 125mm lengthÂ
silica gel absorb the water vapour in air.
here I am usedÂ
steadyÂ
model was k epsilon- RNG - standard wall treatmentÂ
in material
Spicies transport on make mixture of water vapour + air
in spicies transport- volumetric on and inlet diffusion on
i don't know that right or wrong
please correct meÂ
I objective was outlet temperature will be higher than inlet temperature and outlet RH will be decrease compared to inlet RH
REGENERATION TEMPERATURE- 328.15
pipe made of silica gel
April 10, 2023 at 3:06 pm
Tejas Prajapati
Subscriber????
April 11, 2023 at 10:05 am
Forum ModeratorIf you want to absorb the vapour you'll need to either use a reaction on the gel surface (or porous media surface) or a sink (source) term. For the latter you need to account for heat release too.Â
You've got the basics but not the part that actually removes the vapour.Â
- The topic ‘Solid desiccant dehumidifier’ is closed to new replies.
3019
971
857
772
762
