June 27, 2019 at 2:58 pm
Ajucgnr
SubscriberWhile meshing a simple geometry, I face an error "A software execution error occured inside the mesher. The process suffered an unhandled exception or ran out of usable memory". I try to mesh with just 20 numbers of edge division and should be really coarse. Sometimes it works when the number of divisions are higher. Attached are the snapshots of the geometry and the error pop up message
June 27, 2019 at 3:07 pm
Forum ModeratorPlease add the images with the text: staff are not allowed to open attachments.Â
June 30, 2019 at 1:56 am
peteroznewman
SubscriberOn the rare occasions when I get this error, it is because the geometry has some defect. Once the defect is repaired, the mesh works properly. Where did this geometry come from? Try constructing fresh geometry and meshing that.
- The topic ‘Software execution error while meshing’ is closed to new replies.
4893
1587
1386
1242
