Preprocessing
Preprocessing
Skewness in Ansys Mesh
    • krany3
      I found the regions of higher skewness. What should I do to reduce the value?
      Look at what's causing it. Then revise local size settings (and potentially geometry) to remove the cause.
    • krany3
      I will try that. Thanks!
  • The topic ‘Skewness in Ansys Mesh’ is closed to new replies.
