May 11, 2022 at 8:23 pm
amatistac95
SubscriberI am running a DR IR Drop simulation to try and find out the min and max voltage of a pcb layout. From a net, to show the resistance along the net.
However, when I follow the instructions from the DC IR DROP user guide from ansys learning hub, the result shows no change in the color scale. I was wondering if any of you have any odcumentation that could help me better understand what I am doing wrong?
Or in case you have a design example that I could use. I would appreciate your help. All I am doing is selecting the source and running the simulation. Thank you.
August 3, 2022 at 4:57 amPraneeth
Ansys EmployeeHi amatistac95,
Did you go through the getting started guides and the examples in the SIwave? If not, kindly go through them for better understanding.
All the very best,
Praneeth.Viewing 1 reply thread- The topic ‘SIwave: DC IR DROP simulation’ is closed to new replies.
5694
1891
1419
