July 28, 2022 at 2:27 pmsdmahaneySubscriber
I have a very complicated model with lots of bolts and contact running well.
I can get bolt forces and reactions and plots like this contact pressure plot. But I don't see how to pick just one of these surfaces and get the total force on it.
A force reaction probe is defined on the contact set, but it looks like (after a couple hours to re-run) it's going to give me one set of totals for the whole set, not just one face pair.
July 28, 2022 at 2:29 pmsdmahaneySubscriber
[this is in a Mechanical static structural study]
July 28, 2022 at 2:53 pm
July 29, 2022 at 2:13 amCharudatta BandgarForum Moderator
Hello Shawn Mahaney
Regarding your question on Ansys Mechanical, please post it on ANSYS Customer Portal or Ansys Learning Forum based on the type of license that you have. This ANSYS Discovery Community Forum is intended for seeking help on ANSYS Discovery products. Thank you for your understanding!
Regards
- The topic ‘Single surface contact force’ is closed to new replies.
- Unable to attach geometry 2024 R2
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Inventor 2025 files
- SpaceClaim stops sharing topology
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- solidwork parameters for optimization in ansys
1727
624
599
591
366
