May 5, 2020 at 2:58 pm
Rohannnn
SubscriberHello I'm repeatedly facing a problem when I'm carrying out simulation of bldc in Maxwell. It states:-
Project1 (C
Users/user/Desktop/)
RMxprtDesign1 (Brushless Permanent-Magnet DC Motor)
[info] Failed to delete temporary files on server 'Local Machine'. Found File Setup1.da1. You may want to manually delete directory 'H:\rmxprt_user-PC_4664.pjt'.
[error] Unable to create child process: bldc.exe, error code = 267
[error] Simulation completed with execution error on server: Local Machine. (8:24:07 PM May 05, 2020)
This appears the moment I specify required parameters and go for simulation. Please help me through this!! -
June 12, 2020 at 7:09 pm
Charlotte Blair
Ansys EmployeeTry running a Rmprt example from our Open Examples folder. If this model is able to run then it is something in your model which as an Ansys employee I can not provide direct assistance. Also try to delete file as defined in error message and if that doesn't work try not using a parameter and just a defined number if the model runs then its an issue with your parameter setup. Be sure to check if you need to use local or project variable for your parameter. please see our documentation for help. We also have a Ansys How To Channel on Youtube which may also be helpful.
July 27, 2023 at 5:56 am
Dhanavath Krishna
SubscriberHello ANSYS,
while trying to simulating the RMxprt BLDC model, I am getting "Unable to create child process: bldc.exe, error code = 5 (11:09:29 AM Â Jul 27, 2023)" error.
Please help me in this problem.
- The topic ‘Simulation problem in ansys Maxwell’ is closed to new replies.
5694
1891
1419
