July 29, 2021 at 11:07 pm
Nelge
SubscriberI am trying to figure out how to simulate free standing permanent magnets. For example can maxwell visually simulate what happens if you put 2 magnets fairly close together? Obviously in the real world they attract each other and become one. Can this be visually simulated in maxwell?
Thank you
August 1, 2021 at 4:45 amNKC
Forum ModeratorHi @Nelge You can not visualize the magnets moving together themselves by just simulating two magnets apart. Instead, the following can be done.
You can do a parametric setup with varying distances and maxwell will calculate the fields and forces between the two magnets at all these distances.
after the parametric simulation, you can animate the setup with all the distances given in your parametric and visualize the field distributions changing as the magnets move closer or away from each other.
You can also plot the forces at all these distances.
Refer Maxwell help on field amination for additional information on how to create the animation.
Regards Navya
August 2, 2021 at 10:29 pmNelge
SubscriberThank you this helps.
I also tried playing around with one of the rotational examples, I made the stator and Rotor of magnetic material (flux directed towards centre of cylinder), created a motion band for the rotor, and added 0.1 kgm^2 moment of inertia, and simulated what would happened. The video attached shows the animation.
I suppose what I am trying to understand is what are the limits of this software? Because this solution I've made seems to follow my original '2 magnets' situation but with a slightly different setup.
Does this animation show that you can simulate 2 magnets attracting each other?, or have I made wrong assumptions somewhere?
Thank You
Viewing 2 reply threads- The topic ‘Simulation of free standing permanent magnets in Maxwell 3D?’ is closed to new replies.
Innovation SpaceTrending discussions- Three-Phase Voltage Imbalances in dual stator electric generator
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
Top Contributors-
4607
1510
1386
1209
