November 15, 2020 at 3:12 pm
Abdulsalam
SubscriberI am trying to simulate Dielectric Elastomer Actuator under cyclic loading. I have already define my material using the curve fitting as you can see in the attached zip file. The material I am using is Sylgard 184.Â
The circles on the geometry surface represent the electrodes and I drawn them by using FaceSplit and I don't know if this is the way to represent the electrodes and how the load is distributed when applying load to it. I also tried to do static simulation by applying pressure in both side of the elastomer and I notice that both pressures are not perpendicular to each other, and the pressure is not distributed evenly, any ideas how I can solve this?Â
I also added in the zip file a photo of the elastomer and it is fixed by a rigid frame from the top and bottom, in ANSYS I fixed all the four side of the elastomer. IÂ really do not know how to start I have tried to look for any reference that can help but I cant find. I don not know how I can apply cyclic voltages under different frequencies on to my elastomer. By the way, I was using Sine wave to apply the load onto the elastomer during the experimental test .Â
What I want to achieve from the simulation is:Â finding the deformation of the elastomer under different voltages and frequencies. And I don't know if it is really possible to preform this kind of simulation with the student version. I am using ANSYS 2020 R2.
December 4, 2020 at 9:41 amashish.khemka
Forum ModeratornnPlease see if the following post helps:nnnRegards,nAshish KhemkanViewing 1 reply thread- The topic ‘Simulation of Dielectric Elastomer Actuator’ is closed to new replies.
