July 24, 2018 at 5:53 pmpratsat1Subscriber
Hey guys, I've been trying to build a bubble surface with ions attached to it, but the bodies keep getting unified into one body. Id there way to separate them? The bodies are spheres of one size, in contact with a larger sphere and with at least three other spheres at the same time. The error it's giving me is the non-manifold geometry error, so how do I make it manifold geometry?
July 24, 2018 at 7:58 pm
July 25, 2018 at 11:05 amRobForum Moderator
Non manifold is often flagged where you have objects contacting at a point or thin edge. You probably need to overlap the spheres slightly, and then do some geometry manipulation to form the connections.Â
- The topic ‘simulation of bubble dynamics’ is closed to new replies.
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Inventor 2025 files
- SpaceClaim stops sharing topology
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- solidwork parameters for optimization in ansys
624
599
591
366
