February 2, 2024 at 6:16 am
February 6, 2024 at 1:52 pm
Ivonne Marti
Ansys EmployeeHi Karen,
The error is pointing to the Voltmeter IV1 and the switch control Model1, looks like one is Positive and the other is OFF.
Please carefully check the setup of these components. I would suggest checking the characteristics of each one, to do this in the Properties window of each component you can find a direct link to Help.
Note: check also the component IV2 because probably you have the same setting mistake.
Ivonne
February 7, 2024 at 3:07 pm
- The topic ‘Simulating line faults in Ansys Maxwell’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
